Vidmas30 Posted March 14, 2012 Report Share Posted March 14, 2012 Good day, I'm doing project with Vision V120. Now I have done ~100HMI displays and when downloading to PLC I get warning (203): "The size of this project prevents the Upload data from being downloaded to the PLC. Therefore, this project will not be able to be uploaded." Why i get this warning and what does it mean? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 14, 2012 Report Share Posted March 14, 2012 Hi, By use Menu option <Burn "Upload Project"> you can download and save your project into PLC flash memory. Then you will upload this project from PLC flash memory to VisiLogic. This message say, that you project size exceed maximum size available for "Upload" option. You should always have backup copy of your project. If you want to use "Upload" option - you ned to lower number of HMI Displays. But you will add more HMI Displays without possibility to use "Upload" option. Quote Link to comment Share on other sites More sharing options...
linxchas Posted March 14, 2012 Report Share Posted March 14, 2012 Alex, That relevant only to color models. For V-120 you should from file menu go to Project>Properties and diable project upload: Quote Link to comment Share on other sites More sharing options...
