mikey431 Posted April 5, 2012 Report Share Posted April 5, 2012 I tried to download the program from V350 to SD card. Under Info Mode/SD Card, I try to use "Download to PLC" option for "Full Clone" and "Application" option but i keep getting the msg "Password missing" . What should i do before i can get to download the application to SD card? Quote Link to comment Share on other sites More sharing options...
Walkerok Posted April 6, 2012 Report Share Posted April 6, 2012 To be able to copy anything from a PLC to an SD card the SD card must have a password preinstalled on it by using the SD card utility to do so. However, if at the time of the original download of the program into the V350 was not designated as downloadable then you will not be able to copy this anyway. If you go into visilogic and searck for "clone" it will talk about this and there will be a link to "password" that give you specifics about the password needed. Keith Quote Link to comment Share on other sites More sharing options...
