pointBG Posted May 21, 2012 Report Share Posted May 21, 2012 Please Is there anyone who can hepl me? I try to connect EXRC1 and V570, and i need to read DI inputs via EXRC1. I found the example in the VisiLogic help, but I need that inputs as a condition in Ladder programing. My PLC loks them as a Memory Integer. Is there any easy way to read them. Thank anyway. Best reguards Luka Quote Link to comment Share on other sites More sharing options...
Ofir Posted May 21, 2012 Report Share Posted May 21, 2012 Hi, Basicall you can use the example "PLC to EX-RC1- Standard" but you will have to apply one change. In subroutine "INN" net#2 open the struct function and instead of I160, replace it to MB with free address. This means that the vector of integers you receive from the EX-RC1 will be extracted to a vector of MBs that starts with the address you indicate in struct function. Then you can use any if these MBs as codition in your ladder. Quote Link to comment Share on other sites More sharing options...
pointBG Posted May 21, 2012 Author Report Share Posted May 21, 2012 Thank you very much. I have a new question; I found the e-file on the unitrnonics.com about the EX-RC1. And I heard (read) next: "The EX-RC1 has the ability to auto-detect any expansion modules that are connected to it --as long as these modules are digital. In other words, if your system includes only digital I/O Expansion Modules, you do not have to define the Hardware Configuration." Does that mean if I have 3 or 4 IO-DI16s, I dont need to make struct function as I can find in an example? How can I read from these inputs in my PLC? I hope that you will understand this explanation of my problem. Thank you very much, anyway. Luka Quote Link to comment Share on other sites More sharing options...
pointBG Posted May 22, 2012 Author Report Share Posted May 22, 2012 I made something, and It works. So, thanks anyway. Best reguards to next chating Quote Link to comment Share on other sites More sharing options...
