montania Posted May 23, 2012 Report Share Posted May 23, 2012 Hi I sended often E-Mail about GPRS with V570. Now not work it. If I send an E-Mail, going the Status Message on 1, SB 345 1, Status Message 13, SB 345 0, Status Message 2 and then 0. This prozess needed 2 seconds. The Result is, that the E-Mail not is sended. I not understand, why going Status Message on 13. What is the reason? If I click out the check box "SMTP authentication" then is after sending a email, the username und passwort empty. I need help Thanks montania E-Mail-GPRS.pdf Quote Link to comment Share on other sites More sharing options...
