beka Posted July 17, 2012 Report Share Posted July 17, 2012 Hello, in most of my intended applications using the V130/ V350, data logging plays a very important part - and consequently data handling! As much as we like the micro SD cards as storage medium, to transfer data regularily with big hands it is not advisible - especially if an enclosure / box has to be opened in not really clean environment ..... Good would be a USB connector, using a USB stick .... So I tested a microSD/ SD extension cable which can easily be found.. But the results were not good at all, lots of errors in the file structure (and csv files), assume the cable quality was not good/ too long (23cm) and noise very likely the cause of this. Besides the Card in/out signal is not much good using an extension cable. I assume this or similar problems have occured before in regards to data logging with SD; has anybody some experience with SD extension cables ? Or any other better idea? Thanks Beka Quote Link to comment Share on other sites More sharing options...
Damian Posted July 17, 2012 Report Share Posted July 17, 2012 Go wireless. Put a bluetooth or Wifi adapter on the RS232 port and upoad the data that way. If you go Wifi you could patch it into your main network and then you wouldn't have to leave you seat. Quote Link to comment Share on other sites More sharing options...
Damian Posted July 17, 2012 Report Share Posted July 17, 2012 If you didn't want to deal with the battery, you could just pull them and wire DC direct to the batter contacts. Take a look at these. http://serialio.com/products/mobile/wifi/WiSnapAAA.php Quote Link to comment Share on other sites More sharing options...
Damian Posted July 17, 2012 Report Share Posted July 17, 2012 This is a bit bulkier, but you can plug directly into 115/230vac and is probably more industrial. http://www.ebay.com/itm/Serial-RS232-WiFi-converter-module-rs-232-wi-fi-/230669354669 Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted July 17, 2012 External Moderators Report Share Posted July 17, 2012 What about this rugged BT to Serial RS232/RS485: http://www.connectblue.com/products/bluetooth-products/bluetooth-devices/bluetooth-rugged-serial-port-adapter-rbs433/ Quote Link to comment Share on other sites More sharing options...
Damian Posted July 17, 2012 Report Share Posted July 17, 2012 What about this rugged BT to Serial RS232/RS485: http://www.connectbl...adapter-rbs433/ Pretty pricey, but definitely looks like a nice unit. Quote Link to comment Share on other sites More sharing options...
beka Posted July 18, 2012 Author Report Share Posted July 18, 2012 Thanks for the comments .... and more info about my applications: - the Com port is already taken, so no BT / serial possible, besides - my clients are agricultural operators out in the field , no way they will/ should handle these procedures, - must be as simple as possible like swapping cards from time to time (so have 3G router for remote data transfer as well, but still need "safe" procedure) Thanks, Beka Quote Link to comment Share on other sites More sharing options...
Damian Posted July 18, 2012 Report Share Posted July 18, 2012 You can mount more than 1 com port on the device. If setup properly, it should be as simple as pushing a button on the display to "send". If you wanted to go with GSM, you could even automate it entirely and take the people completely out of the equation. Quote Link to comment Share on other sites More sharing options...
beka Posted July 18, 2012 Author Report Share Posted July 18, 2012 Damian, still not clear... - only 1 com port possible if I understand the manual correctly, as we use LAN card as well for the 3G LAN router - and reception here is pretty bad if we have reception at ALL (that has been the idea to use 3G or alike, to "take people out" to avoid issues ONLY way, swapping cards at least in our environment (out in the bush - no WiFi/ GSM ) So as written at top, any suggestion to save securely/ conveniently onto a flash medium Cheers Beka Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 18, 2012 Report Share Posted July 18, 2012 Hi, To improve cellular connection, I will recommend you to use yagi cellular antenna, not cellular signal booster or extender. Google on it and find nearest/cheapest suplyer. BR. Quote Link to comment Share on other sites More sharing options...
beka Posted July 18, 2012 Author Report Share Posted July 18, 2012 Hello, yes agree have had them for test, stationary! On a moving vehicle (e.g. tractor, harvester) not too good (unless the owner is willing to pay for spares) - and driving through an orchard is a different story again. To get better coverage we also tested 3G modems with dual - sims - slots, so we can switch to the best signal ...if there is one! No question without external SD card or USB facility we have difficulties ... Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 18, 2012 Report Share Posted July 18, 2012 Hello. Any SD Card extenders are not supported officially by Unitronics. Reassone for this is simple - long wires are working as antenna and make OPLC unstable. SD Card formatted in fixed file system and Directory Structure. USB stick is not a solution, as it needs special drivers etc. As an alternative, you will collect data when vehicle is at parking slot. There you will use BT or WiFi. For example, 300Mbps Portable Wireless AP/Router of Tenda. Or similar one. Communication will be open when vehicle is in WiFi range. From here you will start to retrive data. B.R. Quote Link to comment Share on other sites More sharing options...
beka Posted July 18, 2012 Author Report Share Posted July 18, 2012 Thanks AlexUT, I understand this pretty well, in theory great, but in our environment just not realistic at all! Mainly these machines e.g. harvesters work during night time or around the clock and "parked" in the field no shed/ garage around. Training people to use a laptop with Wifi etc (I have a 3G Lan router incl. Wifi) for retrieving data for example in a car - NO WAY! My existing unit has a SD card slot, just very simple. As said our plan is to use both possibilty, if possible data transfer (and other functions, like trouble shooting) via 3G Lan router and SD card as backup and in situation where there is no coverage or bad signal. A pity, Unitronic's Visilogic is an excellent software - the best I have seen so far! Quote Link to comment Share on other sites More sharing options...
Emil Posted July 18, 2012 Report Share Posted July 18, 2012 Hi Beka, I agree with you. And - frankly speaking, you're not the first person to ask (and insisting on that) for such extender. But Alex is right - such extender is very dangerous for the card and the congtroller. I have no right to recommend such accessory. I know customers are using it, but on their own responsability! Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted July 19, 2012 MVP 2014 Report Share Posted July 19, 2012 For my two cents worth, regarding antenna, I would suggest high-gain Omni directional. Expecially since it is on a mobile platform. With a yagi it needs to be aimed at the tower, which may not be practical on a vehicle. We have had the discussion about extending the SD card in relation to mining applications as well. Really the SD card ends up being a permanent memory expansion, not a removable storage in these kind of outdoor situations. I have also toyed with the idea of using RFID tags. The PLC can be programmed to load the data onto the tag when placed near the read/write head, also with some touch screen interaction. Then also have a reader on the PC to retrieve the data. It would require some intensive programming to set up initially, and is limited by the available tag memory, but also has some nice features including robustness. You could interface via Ethernet, or possibly CAN. Quote Link to comment Share on other sites More sharing options...
Damian Posted July 19, 2012 Report Share Posted July 19, 2012 This also came up in the old Forum. http://www.unitronics.com/forum/topic.asp?TOPIC_ID=2691&SearchTerms=mitsubishi Would be nice if the SD was acessible on a sealed port from the front. Maybe someday soon we will have SD cards that can be can transfer the contents with a contactless reader. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 20, 2012 MVP 2021 Report Share Posted July 20, 2012 I brought this up a few years ago on the forum for an OEM application. We didn't get the order because there was no easy way to get the data off the card without opening the door. The only way to truly address this is to add USB host capability to our PLC. You can easily extend the USB port. Joe T. Quote Link to comment Share on other sites More sharing options...
beka Posted July 21, 2012 Author Report Share Posted July 21, 2012 Joe, I totally agree. seems I am in a similar position (finishing our project and getting orders if I can find a way for simple data transfer). Though there are other devices e.g. with USB, I believe Visilogic and Unitronics support are unequalled! Beka Quote Link to comment Share on other sites More sharing options...
Ag Automation Posted July 26, 2012 Report Share Posted July 26, 2012 Maybe you could try this device. I have know idea if it would work, but the idea sounds good. http://www.eye.fi/how-it-works/basics Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted July 26, 2012 MVP 2014 Report Share Posted July 26, 2012 Here's another one: http://www.flu-card.com/ However one small hitch, most of the Unitronics models use MicroSD rather than the fullsize cards. Quote Link to comment Share on other sites More sharing options...
beka Posted July 28, 2012 Author Report Share Posted July 28, 2012 Thanks AG automation and Simon, I can implement WiFi via the 3G LAN router already - again I need a simple methode for simple data transfer. It is very unlikely that an operator or even orchard manager brings his laptop/ smartphone routinely close to the PLC for downloading. Maybe twice but not more during very stressy harvest time; Swaping a SD card or USB stick is just too simple! These WiFi cards look interesting, though only for SD not micro SDs as found with V130/ 350. Cheers Beka Quote Link to comment Share on other sites More sharing options...
Ag Automation Posted July 29, 2012 Report Share Posted July 29, 2012 How about transferring the info through the ethernet port to a cheap netbook and then to a USB stick? Maybe this is not any better than my previous thought. I am not certain if you could have it automatically transfer directly to the USB stick on the netbook with Unitronics software or not. But there should be some way. But I guess that is still a little combersome. thought maybe would be another option. then use the netbook to display a video camera to help make an exuse of why it is needed. Quote Link to comment Share on other sites More sharing options...
