Dave Igo Posted August 11, 2012 Report Share Posted August 11, 2012 I've had a V350 in the field for demonstration and endurance test purposes for 2 1/2 years. The software is obviously outdated. The unit was recently struck by lightening and although I have a copy on my laptop I can't open it. I get the following message. You are trying to open a newer project with on older version of software. (I grabbed the latest off of the Unitronics site). Database of software is 142 Database of Project is 145 Can anyone please help me retieve this, it was actually years of work with very poor backup on my part. Thank you in advance, Dave Quote Link to comment Share on other sites More sharing options...
Emil Posted August 11, 2012 Report Share Posted August 11, 2012 You just need to download the lates version of VisiLogic V9.4 from our site www.unitronics.com (Support page > Downloads). You even don't need to delete thhe version you already have in your PC. Version swapper will let you to keep both versions and switch easilly between them. Quote Link to comment Share on other sites More sharing options...
Dave Igo Posted August 11, 2012 Author Report Share Posted August 11, 2012 Thank you..... downloading now. I'll let you know. Quote Link to comment Share on other sites More sharing options...
Dave Igo Posted August 11, 2012 Author Report Share Posted August 11, 2012 At 9% of download I get a "Access is Denied" and the install aborts. Tried uninstalling old version, disableing UAC and nothing helps. Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 12, 2012 Report Share Posted August 12, 2012 What is the size of the setup file you have downloaded? Make sure that the download was completed successfull (the file size is around145Mb). Then make sure you are installing VisiLogic with administrator rights. Quote Link to comment Share on other sites More sharing options...
Dave Igo Posted August 13, 2012 Author Report Share Posted August 13, 2012 Gentlemen, Thank you for your help. I was able to open the software by downloading again. I believe that after I disabled the UAC I should have done a reboot of my laptop. Today everything worked fine. Thanks again. Quote Link to comment Share on other sites More sharing options...
