Dale Posted September 30, 2012 Report Share Posted September 30, 2012 I have Visi 9.4.0 and i am running Windows 7 (64 bit). I am using for the first time. When I drag a contact onto a net I never get a Select Operand and Address box. All I get is a small box with MB in blue above the contact. I cannot click on anything on the screen. I have to hit the escape key and that deletes the contact. I can never continue on and make a program. This also does it in HMI mode. I can never link an object to an operand. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 1, 2012 MVP 2021 Report Share Posted October 1, 2012 The Select Operand box has to be somewhere. Do you have multiple monitors? Joe T. Quote Link to comment Share on other sites More sharing options...
Damian Posted October 1, 2012 Report Share Posted October 1, 2012 Also, check your windows "themes". If you stray from the default windows themes it can cause some items in visilogic to display incorrectly or not at all. 1 Quote Link to comment Share on other sites More sharing options...
