Martin1 Posted October 3, 2012 Report Share Posted October 3, 2012 Hello all, I am having an issue sending an sms alarm via Com Port 1 on a V130 on a enfora1308 modem. I have done it before on a V570 and worked fine. The Modem SB80 is High & the GSM signal quality is at 16. When I press Key #9 on the Keypad it should send a test message. I have attached the config below. Could someone help me before I pull all my hair out! Regards Martin Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted October 4, 2012 MVP 2014 Report Share Posted October 4, 2012 Open your SMS configuration, look at the top right corner, it is set for COM2. Change this to COM1. If that was the only problem, then you should be up and running. Link to comment Share on other sites More sharing options...
Martin1 Posted October 4, 2012 Author Report Share Posted October 4, 2012 Thanks very much Simon. It's always the very small things that catch you out! Link to comment Share on other sites More sharing options...
luiscostaest Posted June 19, 2015 Report Share Posted June 19, 2015 hello ,I wonder if it is possible , with the v130 , write a number on the screen and clicking on the "enter" for example, send a test message to the number that was written.thank you Link to comment Share on other sites More sharing options...
s.pratt Posted June 19, 2015 Report Share Posted June 19, 2015 hello , I wonder if it is possible , with the v130 , write a number on the screen and clicking on the "enter" for example, send a test message to the number that was written. thank you Hello, This is possible by linking an ASCII string on screen where the user will enter the phone number. Then link this string the phone book as a number to send to. Hope this helps. Link to comment Share on other sites More sharing options...
luiscostaest Posted June 22, 2015 Report Share Posted June 22, 2015 Thanks very much for the help. Link to comment Share on other sites More sharing options...
