ohaldi Posted October 7, 2012 Report Share Posted October 7, 2012 Hello, I like to compare the real time clock to a MI HEX value. How can I convert the SI31 variable to a MI HEX value? I tried with RTC to UTC but did not work (See picture) Many thanks for your help Otto Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 8, 2012 MVP 2021 Report Share Posted October 8, 2012 An integer register has an inherent HEX value; all you have to do is Store SI 31 to an MI and you'll get the same "value", but if you view it in HEX mode the numbers won't mean anything. What is the end result you're looking for? Joe T. Quote Link to comment Share on other sites More sharing options...
