jackfin Posted November 30, 2012 Report Share Posted November 30, 2012 Hi All, I'm new with unitronics logics and should modify some bits of ladder-code and am in need for some assistance. Case 1: - I have an increasing counter (cumulative) - I need to send a 500 ms pulse to a relay every time 1000 units have accumulated (relay on for 500 ms and then off until next 1000 units are counted) Case 2: - I get falling edge pulses from a source to a digital input - How could I count the pulses for ten minutes and then send the sum of them to a output multiplied by a constant to an other input? After ten minute count the counter should be reset to zero but still send the constant of the preivious ten minutes untill we have a new value. All the hardware wiring is done. With kind regards, Jack Quote Link to comment Share on other sites More sharing options...
