tommyt Posted October 30, 2010 Report Share Posted October 30, 2010 Hi, I am using the Jazz R31 and cannot seem to make the timer function as I would like. I have three timers in my program, I use the word "timer" as an interval type timer, not hh.mm.ss. I have a function that needs to be triggered by an input and run for a set time (via) HMI and addressable in 10 msec multiples. I have tried to use the standard time function, and set it for "ss" display. This gets me down to seconds only. I could not see where I could even divide the value by 100 to get the timing correct, or the HMI to display "X.XX". Plan 2 was to use the SI1, run the timer, and set a zero back into the register before the next trip. This worked, I was able to get the decimal where I wanted it, and the timing was correct. Besides being bulky, I need to access 2 of the timers simultaneously, so clearing the register is not really possible as I see it. I am asking here as I have been spinning my wheels for a while now, and before I try to do something with counters triggered off the SI1 pulse, was wondering if there was a simpler, better way to do this seemingly easy task. Thanks for any suggestions. -tommyt Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted October 31, 2010 Report Share Posted October 31, 2010 The standard timer operand of U90 Ladder provides a resolution of milliseconds. To use a timer choose Contact, and in the drop-down list choose T. For more information refer to the help file under Ladder >> Elements >> Timers (T) Quote Link to comment Share on other sites More sharing options...
tommyt Posted October 31, 2010 Author Report Share Posted October 31, 2010 Thank you, Stein, I have been able to go to the timer page as you stated, and can set a preset there and it works as advertised. My problem has been to get the HMI to input the information in the .01 increments. I am only able to go to the "SS" level which I can only get it to accept 1 second increments rather than the .01 as is possible in the preset page. Do I have to go through the setting of the SI 141, ect for each timer and enter the setting that way?? -tommyt Quote Link to comment Share on other sites More sharing options...
