speed Posted November 5, 2010 Report Share Posted November 5, 2010 HI I'M TESTING A NEW GSM MODEM AND I saw that the JZ-PRG SERIAL DOES NOT WORK. THE MODEM IS HUAWEI GTM900. I USE A 6 WIRE STANDARD CABLE Properly CONNECTED HOW TO SCHEMA FOR SIEMENS MODEM AND CONNECT THE POWER OF JZPRG ON 1 AND 6-7 PIN OF MODEM. I noticed that THE VOLTAGE ON THE PIN IS 0,10V WITH SERIAL CONNECTED OR WITHOUT. I MADE THE COMPARISON WITH A MODEM WAVECOM AND I HAVE SEEN THAT WHEN I CONNECT THE MODEM WITH JZ-PRG THE voltage drops to 0.03 V. DO I HAVE CONNECT A RESISTANCE? IF IT'S YES WHAT'S IT TYPE. I DID ANOTHER TEST I GAVE VOLTAGE TO JZ-PRG OF WAVECOM AND I CONNECT THE GND AND TX RX OF HUAWEI. THE PLC DID THE INITIALIZATION AND IT WAS SENT AND RECEIVED SMS. SURELY it is a JZ-PRG power problem. Quote Link to comment Share on other sites More sharing options...
Emil Posted November 6, 2010 Report Share Posted November 6, 2010 Dear Speed, Despite most of the modems use AT commands language. each modem has specific set fo commands, "slighly" different from others. That's why we don't support just any modem, but specific list. We don't know and never heard about the modem you stated. There is practically no chance it will work. You need to use one of the modems we support. I recommend you to work with Enfora and to use our GSM kit, which includes all accessories needed and will make connection fast and easy. Don't forget in your project you need to check "Use SMS" in SMS window, and NOT Use modem. Quote Link to comment Share on other sites More sharing options...
speed Posted November 8, 2010 Author Report Share Posted November 8, 2010 HI EMIL Thank you for responding. MY MODEM HAS STANDARD AT COMMAND. IT'S WORK VERY WELL WITH M90 AND VISION PLC. I ASK YOU THE RANGE VOLTAGE OF JZ-PRG AND IF I CAN USE OUTSIDE POWER. THANKS Quote Link to comment Share on other sites More sharing options...
speed Posted November 8, 2010 Author Report Share Posted November 8, 2010 Connecting only tx, rx and gnd they work very well. (m90 schema) Quote Link to comment Share on other sites More sharing options...
