DaveE Posted May 7, 2013 Report Share Posted May 7, 2013 Good Morning Completely new to this and have decided to venture out to get a PLC to do what I want it to do Basically need a counter to count the number of inputs it gets. Parts going down a conveyor to be diverted either to Bin A or Bin B If they dont go to Bin A then they will go to Bin B I have a blocking device (pnematically activated) that will lower and raise (I hope) Customer will set the number of parts to go to Bin A, this will also be the number of parts into Bin B Theory is If the set point is set at 25 Start, output is set to lift cylinder Parts go past a sensor, counter counts these parts, when it gets to the set point, cylinder drops, and then when it gets to the set point again, cylinder raises Repeats ad infinitum. I have made a start on what I think should work, but wanted expert opinion All offers of help will be graciously recieved Thanks for listening (reading) my babble I hope my program is attached! Start.vlp Link to comment Share on other sites More sharing options...
kapil Posted July 2, 2013 Report Share Posted July 2, 2013 Start_kapil.vlphi Dave it is so long time you posted your query, i hope you will solve it, though if not then a little help from me. I have attached the logic modified yours. hope it will help you. Regards. kapil vyas Link to comment Share on other sites More sharing options...
