Siemens Combustion Center group has 90 degree can bus servos in several sizes including 20Nm, but I do not know if they are an open protocol or a special only to Siemens version of canbus.
The general number for their offices in Chicago are (224) 366-8445.
Tell them what you want and see if they have anything.
Keith
If you are referring to the SQM45 and SQ48 then no these won't work. They use a proprietary Siemens version of canbus that can only be used with the LMV5x burner managers. I uses these all the time along with the LMV5x and they would have been perfect if they worked with the standard canbus.
