Guest gsxr1000au Posted May 27, 2013 Report Share Posted May 27, 2013 Looking for the pin-out for the MJ10-22-CS32 Modem Programming cable. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted May 30, 2013 Report Share Posted May 30, 2013 Sorry--must have missed this. If you are still looking, searching for MJ10-22-CS32 in the Help file pulls it up. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted May 30, 2013 MVP 2014 Report Share Posted May 30, 2013 Hi Cara, The MJ10-22-CS32 does come up in the helpfile, however there is no diagram or pinout. You have posted the MJ10-22-CS25 pinout. The MJ10-22-CS32 is the cable required to connect a PC to a Wavecom Fastrack modem for initialisation, or to use as a PC-side modem. I wouldn't really expect it to be in the help since Wavecom have fallen out of favour as a supported modem. However we still have a lot of them in the field and working. My pinout table is currently hand-written on the relevant page of the Wavecom manual, which I should not post for copyright reasons. If needed I can transcribe to generic form. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted June 4, 2013 Report Share Posted June 4, 2013 ooops!! I misread the number--Sorry! If the original poster still needs it, please contact support@unitronics.com. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 5, 2013 MVP 2014 Report Share Posted June 5, 2013 This is under control, as far as I know. Quote Link to comment Share on other sites More sharing options...
Guest gsxr1000au Posted June 5, 2013 Report Share Posted June 5, 2013 The Pin Out map Simon sent through to me worked ok. I do think this should be put into the Help file though. Without Simon's prompt reply to my email we would have been in strife... Quote Link to comment Share on other sites More sharing options...
Emil Posted June 5, 2013 Report Share Posted June 5, 2013 Just small note - despite CS32 is Unitronics part number, this is the standard modem supplied with Sierra Wierless modem. I guess its pin out can be found in SW site... Quote Link to comment Share on other sites More sharing options...
