Hardus Posted June 7, 2013 Report Share Posted June 7, 2013 Hi, Using Remote Opertator. I'am connecting to a v130 via LAN. TCP settings, PLC name, port nr are all correct. I use Unit ID 0 (direct) It did work in the past but now gives me: "cannot communicate with the PLC with specified UnitID!" Any ideas? I can connect to it via Remote Access with the same settings. Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 7, 2013 Report Share Posted June 7, 2013 New computer? Maybe Remote Operator has some problems with privileges (it tries to extract files needed for it to work). Try running it as administrator. Quote Link to comment Share on other sites More sharing options...
