2rlp Posted November 13, 2010 Report Share Posted November 13, 2010 Hi, I am receiving the attached error. Are the umber of Keypad entries with Min/Max Controls limited to 8? Pl reply asap. Thanks Ron U90Error.pdf Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 14, 2010 MVP 2021 Report Share Posted November 14, 2010 I thought it was 16. Either way, go to Project->Properties and click on the Statistics tab. Your answer will be there. You may have to do Min/Max by using compare blocks and forcing the value in your logic. Joe T. Quote Link to comment Share on other sites More sharing options...
