viper_lasser Posted August 8, 2013 Report Share Posted August 8, 2013 Is it possible to connect / obtain only specified screen from plc ? Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 9, 2013 Report Share Posted August 9, 2013 No. It is similar to VNC for windows. You don't expect to see a screen which is not the actual screen that appears in the PLC. Quote Link to comment Share on other sites More sharing options...
viper_lasser Posted August 10, 2013 Author Report Share Posted August 10, 2013 Where I can find working current version of sources for remote operator / access ? Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 10, 2013 Report Share Posted August 10, 2013 The sources of remote operator are not publicly released. Quote Link to comment Share on other sites More sharing options...
viper_lasser Posted August 10, 2013 Author Report Share Posted August 10, 2013 Are the sources of remote access relased for publicly ? I have old sources from 2011 but from time to time on V1210 application crashes when there is connection via ethernet. After crashing the application plc can response for ping command but I can't connect to my plc any more. I have to reset it by manual power off i power on. What it can be the reason ? OS or old communication driver (dll). Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 10, 2013 Report Share Posted August 10, 2013 The sources of Remote Access are also not publicly released. Are you sure you have the Remote Operator sources from 2011 and not just the program? When the V1210 program crashes you get an error code, do you have it? Have you contacted the support with the information about the crash? What OS version you have on your PLC (including Boot, BinLib) Have you tried updating the OS of your PLC? Quote Link to comment Share on other sites More sharing options...
