yarikgp Posted August 10, 2013 Report Share Posted August 10, 2013 Hi, I have purchased two Jazz R16 PLCs, and trying to reprogramm them to my needs, the only problem I have got is that after I switch power off, all the data saved in the PLC is gone or restored to defaults. Also while I am recompiling the programm and trying to download the program to PLC, I see the power up values - retain values grayed out. What should I do to enable it? I have opened the Jazz, and have seen the Letium battery on board, so I beleave it is good battery, also SB8 return a 0 value. How can it be that the values does not been saved? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted August 11, 2013 Report Share Posted August 11, 2013 Hello, What is the full part number of your PLC model? and Which o/s version is installed on your PLC? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 18, 2013 MVP 2021 Report Share Posted August 18, 2013 On the Download screen, make sure the "Retain values (battery backup) option is selected. Joe T. Quote Link to comment Share on other sites More sharing options...
