Reducing I/O wiring
I am very satisfied with how the Unitronics controllers cut down on panel wiring by interfacing the PLC and the HMI. I am looking for a similar solution to reduce the amount of time spent wiring inputs and outputs. I have found solutions for other systems that use front adapters to plug into the I/O modules and run pre-assembled cable to the terminal boards. If a product exist for the Unitronics controllers that could accomplish this I would very much like to know about it.
  • Upvote 1
