amirm Posted October 4, 2013 Report Share Posted October 4, 2013 Visilogic on Notebooks with 2 Displays = DISASTER.... How to reproduce (and explain) the problem: - Open Visilogic on a notebook with external monitor, in extended dektop mode (each screen has different image) - Insert a new "Direct Contact" box (F5) - When the pop-up asking for operand and address appears, move the pop-up to external monitor - Enter some data and close it - Double click on "Direct Contact" - Pop-up asking for operand and address will appear on same place (external monitor) - click Cancel - Disconnect external monitor - Double click on "Direct Contact" - Pop-up asking for operand and address will appear on unreachable place (invalid coordinates of where external monitor was) - All you can do is press ESC and stop working until you get an external monitor. Solution: When Visilogic opens any pop-up, it should check if coordinates are within visible area of desktop. If not, relocate them to (10, 10) Yours, Amir Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 8, 2013 MVP 2021 Report Share Posted October 8, 2013 Getting a window off a monitor that is no longer connected- Try "Alt-Space" then "M" (Windows Move command) and use your arrow keys to drag it back. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
amirm Posted October 14, 2013 Author Report Share Posted October 14, 2013 Well, that did the trick! I should have read read Windows manual... Thank you very much! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 17, 2013 MVP 2021 Report Share Posted October 17, 2013 It's very handy but I can never remember the Alt-space thing. If you need it again remember to Google "move window shortcut". Joe T. Quote Link to comment Share on other sites More sharing options...
