mckruger Posted October 9, 2013 Report Share Posted October 9, 2013 Hi im trying to use the relay outputs for V200-18-1B this is how ive set it up 0V on negative V1 on normal V2 output connection (or on a normal positive connection) When i link the output to a button push event nothing happens the normal setup for the normal outputs works fine. am i doing something wrong Quote Link to comment Share on other sites More sharing options...
cantcliff Posted September 12, 2014 Report Share Posted September 12, 2014 Are you expecting the relay to power your load or have you connected the output terminals of the relay to a supply source? I ask because it's not quite clear by your explanation. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted September 12, 2014 Report Share Posted September 12, 2014 Hello, Thank you for using our Unitronics Forum. Could you please explain which digital output you are using? (relay/transistor) If you are using a relay output, please note in addition to powering V1 and V2, you will also have to supply power to the relay. The V1 terminal will only power the output logic to close the relay. But once the relay is closed, there needs to be some sort of power to run through it. Please refer to the spec sheet found in the technical library, under our support tab of our website, for wiring configurations. If you are using transistor outputs, you just needs to supply power to V2 and the output will send 24VDC out from the module itself. The issue may then reside in your logic. If you could attach a copy of your program for our review, that would help us to better troubleshoot. Let us know if this helps. Quote Link to comment Share on other sites More sharing options...
