adil Posted October 9, 2013 Report Share Posted October 9, 2013 Hello, I have a problem with my new GSM , GPRS Cinterion TC65 modem, I am unable to initialize it with my PC, I use visiologic OPLC IDE 9.4.0 Build Version 0.it still Gives me the same error code 284 (modem operation failed modem not connected). lines of command that gives me error code is: AT&FAT+CPIN=^XXXX^ ------------------------------------------- ErrorWAIT 3AT^SCFG="GPRS/ATS0/withAttach","off"ATE0&C1&D0&S0X4Q0S0=0V1------------------------------------------- ErrorAT+CPMS=SM,SM,SM---------------------------------------------------------Modem Input ErrorAT^SGCONF=540,540,8AT^SCFG="Radio/Band",1,1AT&W0ATI I need your help, thank you.Best Regards,ADIL Quote Link to comment Share on other sites More sharing options...
adil Posted October 16, 2013 Author Report Share Posted October 16, 2013 I wonder if there is a person who uses the Cinterion TC65 modem in Canada, I just want to know the network provider sms to buy SIM card thanks Quote Link to comment Share on other sites More sharing options...
mc controls Posted May 2, 2015 Report Share Posted May 2, 2015 I had the same problem, try this- change AT+CPIN=^XXXX^ to AT <PIN CODE> change AT+CPMS=SM,SM,SM to AT+CPMS="SM","SM","SM"Hope this helps Quote Link to comment Share on other sites More sharing options...
DanT Posted May 4, 2015 Report Share Posted May 4, 2015 Hi Depending on your location - I am in Ontario Contact Rogers or Telus for the SIM cards. Also, during the configuration, be sure to set the unit to the proper BANDS, they are different from the programmed bands. The command is detailed in the big programming manual. If you need a copy, I can email it to you. dant@sandtron.com Quote Link to comment Share on other sites More sharing options...
