wimzwart Posted November 26, 2013 Report Share Posted November 26, 2013 Hi, I have made a programm with using timers in subroutines, I'm calling the subroutines all the time. The timers are running twice ass quick comparing to my stopwach. Can somebody help me so I can set the timers to real time. The timer is sett as TD. Wim Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted November 26, 2013 MVP 2014 Report Share Posted November 26, 2013 this usually happens if the timer coil is being called twice in the same PLC scan. Check to see if the coil is used twice in your program or you are calling the subroutine twice, or a combination of both. 1 Quote Link to comment Share on other sites More sharing options...
