DanT Posted December 3, 2013 Report Share Posted December 3, 2013 Hi; Any one have experience working with a Wachendoef WDGA 58B Absolute Encoder Multi turn transmitting data via RS485? V130 Com 2 Dant Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted December 5, 2013 MVP 2022 Report Share Posted December 5, 2013 Here's the datasheet on the encoder- http://www.wachendorff-automation.com/fileadmin/pim/WA/pdfs/en/General_technical_data_absolute_encoders_RS485.pdf It looks like it continually broadcasts data. After you untwist your brain from reading the data frame structure you should be able to interface with it using a Protocol scan block. Joe T. Quote Link to comment Share on other sites More sharing options...
DanT Posted December 5, 2013 Author Report Share Posted December 5, 2013 Thanks for the Reference; I have the V130 now reading the data properly and getting the encoder position. Anyone done a CRC-CCITT X16 + X12 +X5 +1 ( Seed 0x1021 ) CRC subroutine? There is an example of CRC calculation , but not for this Dant Quote Link to comment Share on other sites More sharing options...
