anuchisa@yahoo.com Posted December 17, 2013 Report Share Posted December 17, 2013 Dear sirs, Normally, when I finish programming with Unitronic PLC V280. I'm able to upload/backup the ladder from V280 to my computer. However, I can't upload the update/latest value of MI memory (after finish the parameter setting / commissioning). So, when I dowload this backuped program back to another PLC V280. I have to manually adjust the MI memory. Therefore ... I would like to know how to backup the MI memory from V280 to the VISILogic in my laptop. Please recommend. Best Regards Anuchit S, Quote Link to comment Share on other sites More sharing options...
Ofir Posted December 17, 2013 Report Share Posted December 17, 2013 Hi, Using VisiLogic connection menu, you have the option "Export operands to File". You have the option also later to import the file back to the PLC. Another option is using Remote Access under tools menu you can select operand access and import or export operands to Excel. Quote Link to comment Share on other sites More sharing options...
