neurocyber Posted January 25, 2014 Report Share Posted January 25, 2014 I have totally forgotten how to select a particular HMI screen to be the one that comes up first on PLC startup. Thanks Quote Link to comment Share on other sites More sharing options...
HigHTech Posted January 27, 2014 Report Share Posted January 27, 2014 Start-up display is the one. So move the things you need to that one. Quote Link to comment Share on other sites More sharing options...
Walkerok Posted January 28, 2014 Report Share Posted January 28, 2014 You can force any of the screens to come up other than the "start up" screen, but it takes special effort. Every screen has a number that identifies it and can be found by clicking on "View" on the tool bar and then clicking the "HMI Information" button. A small window will pop up that tells you what the SI252 number is associated with every screen. With this information you can write into a net that after first scan you force SI252 to the integer associated with the screen you want to see (or any other event you would want to force a screen where on screen jumps do not make sense). It is easier to just use the "Start Up" screen, but sometimes you want a special screen to pop up for a few seconds then change to a regular running screen (like showing your companies logo and service number for a few seconds on start up). Keith Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted January 29, 2014 Report Share Posted January 29, 2014 Use "Load HMI display" function (Under Utils|HMI) connected to SB2. Quote Link to comment Share on other sites More sharing options...
neurocyber Posted January 29, 2014 Author Report Share Posted January 29, 2014 thank you all got it Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted January 30, 2014 Report Share Posted January 30, 2014 Very cool--three correct answers :-) Quote Link to comment Share on other sites More sharing options...
