ohaldi Posted February 15, 2014 Report Share Posted February 15, 2014 Hello, Since I moved to a new PC with Windows 8.1 FR, I regulary have to reinstall Visilogic that I can start it! I get the following start error message : UnUtGlb1 Un compression Fail. Impossible to continue! I have to reinstall VisiLogicSetup_9_6_Build_00 again with run as Administrator. I also allways start VisiLogic as Administrator. What are the possible causes? Many thanks in advance for any help. Otto Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted March 31, 2014 Report Share Posted March 31, 2014 Hello Otto, Such error may occur due to Windows security/firewall changes. Please consider to reinstall VisiLogic as follow: Open the task manager and close VisiLogic. Delete the file Current_OPLC.udb from: C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\DB Follow the attached document to disable the UAC and run VisiLogic (Win 7) If the problem still occur (Win7/8): Backup you projects and delete all the files related to Unitronics installations. · Erase the “Unitronics VisiLogic_C” folder from- C:\Program Files\Unitronics · Erase the “Unitronics” folder from- C:\Program Files\Common Files. · Perform Windows update and restart the PC · Log-on as administrator · Save the setup file on your desktop and make sure that the installation file is not blocked (Right click on the file>Properties) If yes, just click on the unblock button: Install VisiLogic. If software opened properly, Go to the properties of VisiLogic shortcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. i hope it helps.. Quote Link to comment Share on other sites More sharing options...
