james long Posted March 17, 2014 Report Share Posted March 17, 2014 Hi, I'm new to this. So all help will be greatly appreciated. My mind works a little backwards so my questions might be dumb but for me necessary. My first question is what is the step to connect my function in my logic to the buttons on my screen. I can do alot of the ladder but I've never worked with this before so it is all new to me. Again thanks for any help. usp-070-b10, uid-0808-ths, exrc1, io to16, io atc8 Quote Link to comment Share on other sites More sharing options...
DanT Posted March 21, 2014 Report Share Posted March 21, 2014 Hi James; In the Properties Block for the Button ( Lower Right Part of UniLogic Screen) Look for Actions( normally at the top of the List) and open Then Add New Action -- Set bit and link it to the ladder variable. You can Set the Ladder Bit when button is pressed, and reset the Bit when button is released (or do the reset in the ladder) Actions can also call Screen jumps, set VNC Connection, and others Dan Thomas Quote Link to comment Share on other sites More sharing options...
james long Posted March 25, 2014 Author Report Share Posted March 25, 2014 Thank you Dan. I have a new problem that I have not been able to find an answer to anywhere. In graphs and meters there is meter and trend. I am using the meter in my hmi as a thermometers but I do not how or if it is possible to put the incrementation on them to represent the temperature. This is one of my main on screen concerns now. I have 4 screens all together. I would upload but I don't know how to get a pic of the screen design without screen shoting my entire computer screen. The forum wont allow upload of an exported shot of hmi, and I don't have permission to use the gallery for some reason. This is frustrating.... Once I get the basic just of it I'll have it licked its just the terminology is new to me on some stuff, and I've never even seen anybody do this. I am learning this totally on my own.... so all help will much appreciated... James Long Quote Link to comment Share on other sites More sharing options...
DanT Posted March 26, 2014 Report Share Posted March 26, 2014 Hi James; On the Meter Graph, there is no provision to add labelling. You will have to do the labelling manually with Text and Numeric Elements. Dan Quote Link to comment Share on other sites More sharing options...
james long Posted March 27, 2014 Author Report Share Posted March 27, 2014 How would I get the spacing and numbering correct to represent the the correct temperature. I'm not trying to sound simple but I just don't understand why there is no option for it on devices that designed for manufacturing and used alot for heating processes...... UUGGGHHHH... Being new to this does not help..Does anyone out there have any ideas on a thermometer or have one maybe done. With instructions on how you got the increments correct. Sorry I sound so simple James Long Quote Link to comment Share on other sites More sharing options...
