Damian Posted April 4, 2014 Report Share Posted April 4, 2014 How do I get around the "The CSV file you have selected cannot support the exported values" message that pops up every time I try to save the operands? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 6, 2014 MVP 2023 Report Share Posted April 6, 2014 What operands are you trying to save? Joe T. Quote Link to comment Share on other sites More sharing options...
Damian Posted April 6, 2014 Author Report Share Posted April 6, 2014 Well ........... all of them really. M, MI, MF, ML, DW. It is nice to have a backup of all the operand values in a PLC. I have had it work fine on some computers, and not at all on others. Hard to understand why since if it is truly just creating a simple CSV file it should not have anything to do with the OS or installation. Quote Link to comment Share on other sites More sharing options...
Damian Posted April 6, 2014 Author Report Share Posted April 6, 2014 BTW, I tried just doing a small subset (for example just MI) and it still choked on them. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 7, 2014 MVP 2023 Report Share Posted April 7, 2014 You do know they added this functionality to Visilogic in v9.5, don't you? Connection->Export PLC Operands to File. I had trouble with it but I think they got it working in v9.6. It's not a .csv file, though. I'm curious why Remote Access isn't working for you as it's what I normally use for this. Granted, I'm stubbornly clinging to XP. What OS are you using? Joe T. Quote Link to comment Share on other sites More sharing options...
kellys Posted April 8, 2014 Report Share Posted April 8, 2014 I have been having the same problem. In the past I was able to use Remote Access to save Operands and then reload them, but now I get the same error. I find myself only being able to use the Export PLC Operands to File within Visilogic with any success. Quote Link to comment Share on other sites More sharing options...
