darknesspic Posted May 16, 2014 Report Share Posted May 16, 2014 Hi I have try to send command to V280 from LabVIEW, I check the command serial port monitor. The command is below HEX : 2F 30 30 52 57 30 31 46 34 32 33 34 39 0D STRING:/00RW01F42349 but no response from PLC, please kindly advise what is the problem?and how to solve Thank you. Quote Link to comment Share on other sites More sharing options...
darknesspic Posted May 16, 2014 Author Report Share Posted May 16, 2014 I have try to send command to PLC. It should be work because I have check by Serial port monitor, the result below HEX->2F 30 30 52 57 30 31 46 34 32 33 34 39 0D ASCII->/00RW01F42349 But the response never come, please kindly advise how to solve the problem? Thank you Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted May 18, 2014 Report Share Posted May 18, 2014 I have try to send command to PLC. It should be work because I have check by Serial port monitor, the result below HEX->2F 30 30 52 57 30 31 46 34 32 33 34 39 0D ASCII->/00RW01F42349 But the response never come, please kindly advise how to solve the problem? Thank you Networking issues are the ones that take most time and effort to debug. Your first steps should be: 1. Go to online mode and determine if the transmissions are received by the PLC. To do that press the touch screen for 5 seconds (for non-touch screen press the (i) button), then enter the code (default 1111), go to serial-->monitor. In that screen you can see the actual Tx/Rx communications. 2. If the transmission is OK, start debugging your code - comms configuration, baud rates, Scan commands etc. 3. If you still cannot solve this issue, please send your application to support@unitronics.com Quote Link to comment Share on other sites More sharing options...
darknesspic Posted May 28, 2014 Author Report Share Posted May 28, 2014 Thank you for your advice, I have solved the problem Quote Link to comment Share on other sites More sharing options...
