Robin P Posted May 22, 2014 Report Share Posted May 22, 2014 I want to copy from an Array (INT16 × 15) to a single DTI cell which holds a similar array. In effect I'm trying to copy one dimension to another. Does the function 'Copy array to column in DTI' allow this? The compiler allows me to set the function up, but no data seems to be transferred. Regards, Robin Proctor Quote Link to comment Share on other sites More sharing options...
Ofir Posted May 26, 2014 Report Share Posted May 26, 2014 Hi, If the structure of the data table contains the array you described then one of the columns is from type array INT x 15 Then using read row or write row you can read or write data to a specific row. Note that you need to create another struct using the data table struct in order to link it to the read row or write row. (This struct will contain the array where you can either fill with values or get the values from the Data table). Quote Link to comment Share on other sites More sharing options...
