RBC Posted May 28, 2014 Report Share Posted May 28, 2014 Hi. If i stop the drum sequencer all outputs stay on instead of turning off if drum is not active. Is it a fault on fb or not. I would imagine that if you stop the drum midway, it should turn off all outputs and reset to stage 1 if started again. Thanks. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted May 28, 2014 Report Share Posted May 28, 2014 Hello, Thank you for using our Unitronics Forum. When the drum sequencer scan block stops being energized, it will finish the time remaining in this step, and remain static in this step. Once it is energized again, it will continue to run from where it last left off. In order to restart the process if de-energized, you must create an additional step where there the timer is 0 and all the outputs are off. In the logic, you will use the Go To Step block when the trigger is toggled off. This will be the all outputs off step. See below: Quote Link to comment Share on other sites More sharing options...
