dulu Posted June 22, 2014 Report Share Posted June 22, 2014 I have a problem with VISILOGIC v 9.7.0. When i want to send sms and i click on SEND SMS icon on the ladder it says "UnFBCom1"," Run Time error 2006". After that VISILOGIC crashes. It has nothing to do with project i'm working on because even in sample programs when i click on SEND SMS on the ladder it crashes too. I followed recomended advices: UAC is turned off I run as administrator I reinstalled VISILOGIC - including upgrade available soft. Nothing helped. OS: WINDOWS 7 profi,64-bit, I run it on Win Vista and the same thing happened. There is no problem using version 9.4.0 Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted June 22, 2014 Report Share Posted June 22, 2014 Hi Dulu, Regarding the SMS Send FB, our R&D issued a DLL which solve the problem, here is the link to download: https://unitronics.exavault.com/share/view/3rsn-2fif5oc6-3y4omovw Please close VisiLogic. Extract the zip file and copy/paste the DLL file to VisiLogic installation folder in the following path: C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\FB_Lib\Dll Please let us know the results. Quote Link to comment Share on other sites More sharing options...
dulu Posted June 22, 2014 Author Report Share Posted June 22, 2014 Thanks, it's solved Quote Link to comment Share on other sites More sharing options...
mvalkama Posted June 23, 2014 Report Share Posted June 23, 2014 Could I also try that DLL? Got same or similar problem on Windows 8.1 Update 1 where opening Send SMS block fails with 2006 error. Although I'm also getting 440 Automation error after that before Visilogic exits. Did reinstall as well and after checking other blocks, only Send SMS seems to cause crash. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted June 23, 2014 Report Share Posted June 23, 2014 Of course you can. Also, we will be issuing a version shortly that fixes this issue. Quote Link to comment Share on other sites More sharing options...
mvalkama Posted June 23, 2014 Report Share Posted June 23, 2014 Of course you can. Also, we will be issuing a version shortly that fixes this issue. Should have added that I asked because the download link appears to be dead. I'm getting "Files are no longer available" response. Can you enable the link again or if the new version is coming in few days I can wait for it. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted June 24, 2014 Report Share Posted June 24, 2014 Should have added that I asked because the download link appears to be dead. I'm getting "Files are no longer available" response. Can you enable the link again or if the new version is coming in few days I can wait for it. Please follow this link and follow the instructions above. https://unitronics.exavault.com/share/view/3w04-bv9tixxk Quote Link to comment Share on other sites More sharing options...
mvalkama Posted June 24, 2014 Report Share Posted June 24, 2014 Please follow this link and follow the instructions above. https://unitronics.exavault.com/share/view/3w04-bv9tixxk Looks like this solved the problem. Thanks! Quote Link to comment Share on other sites More sharing options...
