Robin P Posted July 7, 2014 Report Share Posted July 7, 2014 I 'm trying to use this Ladder Function to copy one array (of integers) to another. As I understand it, parameters A and B specifiy the source array and offset, parameters D and E specify the target array and offset, and parameter C specifies the length (no of items) to be copied. I would have expected parameter C to be an integer, but the compiler is demanding an array! Have I misunderstood the function? Robin Proctor Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted July 7, 2014 Report Share Posted July 7, 2014 Robin, You got it right. It isn't clear why Unilogic demands using an array. Can you please attach an application demonstrating this? Quote Link to comment Share on other sites More sharing options...
Robin P Posted July 7, 2014 Author Report Share Posted July 7, 2014 Hello Eyal, It seems the function requires a UINT and will not accept an INT. That is why it was not offering my original tag - which was an INT - and also offering me some arrays I had created of type UINT. I think we are systems go again, thank you. Robin Quote Link to comment Share on other sites More sharing options...
