Guillaume80 Posted July 7, 2014 Report Share Posted July 7, 2014 Hi, Is it possible to export the modbus coils and registers tables from Unilogic in a file, or at least print it ? Thank you for your help. Quote Link to comment Share on other sites More sharing options...
Alexander Posted July 7, 2014 Report Share Posted July 7, 2014 You can export the tag information but the options are for all Global, Local, or I/O tags and is not separated by how the tags are used. If you know which registers that Modbus uses this can be a quick way to have the information organized within Excel. Another solution to print the different project elements is to take screen shots of the project from the Modbus configuration and print them individually. Quote Link to comment Share on other sites More sharing options...
Guillaume80 Posted July 7, 2014 Author Report Share Posted July 7, 2014 Thank you Alexander. I guess I'll have to fill my Excel files manually... To the Unilogic dev. team : It could be a simple, time-saving feature to add to a future release of Unilogic... Don't you think ? Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted July 20, 2014 Report Share Posted July 20, 2014 Hi :-) I've forwarded your request. Since UniLogic is still quite new, there are a number of features that need to be added/expanded.Requests from the Unitronics user community does influence the order of preference :-) Quote Link to comment Share on other sites More sharing options...
