dcarey Posted July 23, 2014 Report Share Posted July 23, 2014 is there an easy way to find the last row or last column in a data table? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 24, 2014 Report Share Posted July 24, 2014 Hi, Table structure - number of columns and data types - is fixed. So you always know what is a last column. To know, what is the last row with walid data in table, you should start from clean table, and take care to delete an empty rows by shifting all following rows up and clean the last not used rows. Or keep number of valid rows in variable. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 27, 2014 MVP 2021 Report Share Posted July 27, 2014 You can find the first empty row using the Data Tables Find function block and searching for an empty field based on your data table structure. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
