viper_lasser Posted August 1, 2014 Report Share Posted August 1, 2014 On my laptop I have full hd resolution 1920x1080 and there are some problems with displaying windows. Fonts are too big and windows are not correct displayed Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted August 1, 2014 MVP 2021 Report Share Posted August 1, 2014 Go to: Control Panel Appearance and Personalization Fonts Change Font Size Be sure "Smaller - 100%" is selected. If your Control Panel is set to display All Control Panel Items, then just go to Control Panel/Display and make the same selection. Quote Link to comment Share on other sites More sharing options...
viper_lasser Posted August 4, 2014 Author Report Share Posted August 4, 2014 Go to: Control Panel Appearance and Personalization Fonts Change Font Size Be sure "Smaller - 100%" is selected. If your Control Panel is set to display All Control Panel Items, then just go to Control Panel/Display and make the same selection. My settings in os (win 7 64 bits) are following: http://fastwork.pl/karol/unitronics/WindowsFontsSize.png http://fastwork.pl/karol/unitronics/WindowsFontsSize2.png And setting font size to 100% and display fonts to 100% not resolve the issue. What can be wrong in my os ? Quote Link to comment Share on other sites More sharing options...
Alexander Posted August 4, 2014 Report Share Posted August 4, 2014 Does this occur with all projects or only a certain file? Also, did this occur after an upgrade or re-install of VisiLogic? Quote Link to comment Share on other sites More sharing options...
viper_lasser Posted August 4, 2014 Author Report Share Posted August 4, 2014 It doesn't occur with specific project. For example when I try to open file with project created by previous version than it also font are to big on noticication window. http://fastwork.pl/karol/unitronics/visilogic_font_to_big.png Quote Link to comment Share on other sites More sharing options...
Alexander Posted August 4, 2014 Report Share Posted August 4, 2014 It may be that specific version of VisiLogic that has become affected. I would recommend uninstalling then reinstalling the software. Included are the general reinstallation instructions for VisiLogic which require a couple of files to be manually removed as shown in the error message. http://forum.unitronics.com/index.php?/topic/694-how-do-i-perform-a-full-re-install-of-visilogic/ Using the reinstall instructions these are the two folders that should be manually removed before upgrading versions: Delete the folder “Unitronics VisiLogic_C” from C:\Program Files\Unitronics Delete the folder “Unitronics” from C:\Program Files\Common Files Other settings to check are UAC, which must be disabled. We also recommend running VisiLogic as an administrator. Running VisiLogic as an administrator can be accomplished by right clicking on the VisiLogic icon, choosing Properties, going to the Compatibility tab, and selecting the box labeled Run this program as an administrator. Let us know if that solves this issue. Quote Link to comment Share on other sites More sharing options...
viper_lasser Posted August 8, 2014 Author Report Share Posted August 8, 2014 I have uninstalled VisiLogic, delete all folders and after installing VisiLogic has too big font.I known that is problem with my OS because on my virtual windows 7 on virtual box everything is ok. I'm sorry for confusion. Quote Link to comment Share on other sites More sharing options...
JBrd Posted October 15, 2014 Report Share Posted October 15, 2014 I had the same problem with all unitronics software that i tried. Problem is related to HD-resolution and the choises which were made during Win7 installation. However I managed to fix the problem by following these instructions: http://blogs.msdn.com/b/developingfordynamicsgp/archive/2009/11/25/windows-7-bitmap-fonts-and-microsoft-dynamics-gp.aspx I hope it helps! BR, J 1 Quote Link to comment Share on other sites More sharing options...
Garry Posted December 16, 2014 Report Share Posted December 16, 2014 Thanks JBrd! That worked for me...it was driving me crazy on my new notebook! Quote Link to comment Share on other sites More sharing options...
