dub Posted August 27, 2014 Report Share Posted August 27, 2014 Hay. I am working on my first project with Unitronics and have a problem. On display I don't see any pictures from library (lights- binary image and arrows-button) but when i go to online test-remote acess, they are on screen and working perfectly. Link to comment Share on other sites More sharing options...
Eyal Koren Posted August 28, 2014 Report Share Posted August 28, 2014 Hi Dub, Thank you for choosing Unitronics. Try the following: 1. From Visilogic screen, select the Build menu-->Build All. Then download the application to the PLC. 2. If that doesn't help, select the File menu-->System Images. Select "Restore All System Images to Default". Then download the application to the PLC. 3. In any case, download the most recent Visilogic version (9.7.9) and update the PLC firmware to 3.9.6 (most recent). If you need guidance in doing so please let me know. Link to comment Share on other sites More sharing options...
dub Posted August 28, 2014 Author Report Share Posted August 28, 2014 Hi Dub, Thank you for choosing Unitronics. Try the following: 1. From Visilogic screen, select the Build menu-->Build All. Then download the application to the PLC. 2. If that doesn't help, select the File menu-->System Images. Select "Restore All System Images to Default". Then download the application to the PLC. 3. In any case, download the most recent Visilogic version (9.7.9) and update the PLC firmware to 3.9.6 (most recent). If you need guidance in doing so please let me know. I have try steps 1 and 2 but nothing change. Then i have gone thru System upgrade wizard where its says that upgrade not needed > Advanced . All four steps finished successfully but even then everything stays the same, no pictures on HMI. Every time i download program to hmi, same question appear: "The images in your project are different from the images in the PLC. Do you want to download these images?" If i click "yes", it starts programming the Flash and that last few minutes with no changes finally. Few days before i was playing with V570 with no such problem. Link to comment Share on other sites More sharing options...
dub Posted August 30, 2014 Author Report Share Posted August 30, 2014 Hi Dub, Thank you for choosing Unitronics. Try the following: 1. From Visilogic screen, select the Build menu-->Build All. Then download the application to the PLC. 2. If that doesn't help, select the File menu-->System Images. Select "Restore All System Images to Default". Then download the application to the PLC. 3. In any case, download the most recent Visilogic version (9.7.9) and update the PLC firmware to 3.9.6 (most recent). If you need guidance in doing so please let me know. Thanks for reply. I have tried all but it doesn't help Link to comment Share on other sites More sharing options...
dub Posted August 30, 2014 Author Report Share Posted August 30, 2014 Hi Dub, Thank you for choosing Unitronics. Try the following: 1. From Visilogic screen, select the Build menu-->Build All. Then download the application to the PLC. 2. If that doesn't help, select the File menu-->System Images. Select "Restore All System Images to Default". Then download the application to the PLC. 3. In any case, download the most recent Visilogic version (9.7.9) and update the PLC firmware to 3.9.6 (most recent). If you need guidance in doing so please let me know. On HMI is only visible background from pictures. Link to comment Share on other sites More sharing options...
Eyal Koren Posted August 31, 2014 Report Share Posted August 31, 2014 Please send the application to support@unitronics.com for further review. Link to comment Share on other sites More sharing options...
