zbic Posted September 23, 2014 Report Share Posted September 23, 2014 Hi, I am starting a new project on V350 with IOA14A02. I am simulating 4-20 mA input and trying to use linearization. X1: D#=819 Y1: D#=0 X2: D#=4095 Y2: D#=10 X=MI 0 Y=MI 20 I have no problem with the input MI0 I can see the full range when I change the potentiometer. BUT MI20 does not show any result. I am checking older example I have done and that works on the v130 and it seems I have done the exact same thing. What I am missing? Thanks Amir Quote Link to comment Share on other sites More sharing options...
Alexander Posted September 23, 2014 Report Share Posted September 23, 2014 Hello, Is the linearization function block receiving power? It may accidentally be in a subroutine that is not being called. If it is receiving power I would search for other instanced of MI 20 being used in the project. It may be used or overwritten by another function block accidentally Quote Link to comment Share on other sites More sharing options...
zbic Posted September 23, 2014 Author Report Share Posted September 23, 2014 Hi, Thanks for you quick advice, The block does receive power, and the strange thing is that using the math linearization I am getting the problem described above, but if I use variable numeric and use the linearization it does work. MI 20 is not used elsewhere. ?? Quote Link to comment Share on other sites More sharing options...
Alexander Posted September 24, 2014 Report Share Posted September 24, 2014 If possible, please post your code so that we can see if anything else would be causing it to reset to 0. If you are describing the linearization function on the HMI element, numeric variable, that is only for display purposes. Quote Link to comment Share on other sites More sharing options...
Henny Posted September 24, 2014 Report Share Posted September 24, 2014 Hello Also a simple test to see if MI20 is not overwritten somewhere else within the program is to just change it,s value online with Visilogic and see if it keeps the value that you have last written to it. If so then at least you know that it,s not overwritten and that the problem is within the linearization function. Regards Henny Quote Link to comment Share on other sites More sharing options...
