bettim Posted November 1, 2014 Report Share Posted November 1, 2014 Hello to All, I need to drive stepper motor for one little machine, but before tacking controller want to know if anyone has tried to drive stepper motor with JZ10-11-PT15. With what frequency work well. For me is enough 10-15Khz,(In the manual maximal freq.is 0.5khz for pnp and 32khz for npn) Baho Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 2, 2014 Report Share Posted November 2, 2014 Hi Baho, Jazz does not support direct stepper motor. You can use PWM mode of HSO 0 (output 05), npn, to simulate Stepper Motor output. Jazz HSO 0 (output 05) should be configured as PWM with duty cycle 500 (50%) and required frequency. Use Enable bit to start (=1) and stop (=0) pulse output. There is no internal counter of output pulses, nor acceleration/deceleration. You have to realize this in Ladder. With a scan time of PLC (=>100 mSec), and frequency you use (15 kHz), it is impossible to predict if you can succeed or not. It is preferred to make integration and tests. I hope this helps. Quote Link to comment Share on other sites More sharing options...
bettim Posted November 2, 2014 Author Report Share Posted November 2, 2014 Hi, Thank you I understood, I need to write more then 20Net in Ladder (configured PWM,enable output, linearization acceleration/deceleration ..) But it is project for one or two little machines. I wanted to know if I can start the project with jazz or should necessarily pass to other PLC. (JAZZ is simple and cheap ) Regards, BAHO Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted November 3, 2014 Report Share Posted November 3, 2014 Hi, Thank you I understood, I need to write more then 20Net in Ladder (configured PWM,enable output, linearization acceleration/deceleration ..) But it is project for one or two little machines. I wanted to know if I can start the project with jazz or should necessarily pass to other PLC. (JAZZ is simple and cheap ) Regards, BAHO Hi Bettim, As Alex mentioned, you can use the Jazz for controlling a stepper motor driver, but you will have to develop more sophisticated capabilities yourself. As an alternative, you can use Unitronics Vision PLC's (V350 or V130 TR models). they offer: 1. PTO function blocks - enabling easy definition for stepper motors, profiling of acceleration/deceleration, relative/absolute move functions and more. 2. Visilogic - A modern development environment packed with features. Very easy to master. 3. Expanding your project - unlike the jazz, Vision PLC's are expandable in terms of I/O. Obviously, the Vision PLC's are more expensive than Jazz, but you may consider the time saved for developing your application in Visilogic worth much more than the price differences. Quote Link to comment Share on other sites More sharing options...
