Henny Posted January 5, 2015 Report Share Posted January 5, 2015 Hello The link to the "specifications" from Samba SM35-J-T20 doesn,t work and gives and HTTP error. It seems to be the only link that causes a problem because the other links to the specifications from SM35-J-R20,SM43-J-T20 and SM43-J-R20 are working as expected. Tested with IE9 and windows 7 ultimate 32 bit. Just a minor detail Kind regards Henny Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted January 6, 2015 Report Share Posted January 6, 2015 Hello The link to the "specifications" from Samba SM35-J-T20 doesn,t work and gives and HTTP error. It seems to be the only link that causes a problem because the other links to the specifications from SM35-J-R20,SM43-J-T20 and SM43-J-R20 are working as expected. Tested with IE9 and windows 7 ultimate 32 bit. Just a minor detail Kind regards Henny Hi, The link works fine for me (on Google Chrome). For you convenience I attached the document. sm35-j-t20_2.pdf Quote Link to comment Share on other sites More sharing options...
Henny Posted January 6, 2015 Author Report Share Posted January 6, 2015 Hello Eyal Thanks for the PDF. Tested the link with different pc and google chrome and onfortunatly it didn,t work! Got a code like http:// www.unitronics.com/plc-hmi/32d1cb38-21aa-4441c-a5df-91dc569eb9db when clicking the "specification"link for Samba SM35-J-T20 but the specifications links from the other Samba products are working just fine and open the correct pdf file. Kind Regards Henny Quote Link to comment Share on other sites More sharing options...
