iian539@gmail.com Posted February 10, 2015 Report Share Posted February 10, 2015 Hi I have a question about ladder programming (in visilogic): MI1 is coming from a keypad entry, the value range is 0-100. MI2 is coming from an analog input, and is already scaled to the range 0-100. How can i force MI1 to #0 if MI2<20. The MI1 should not be changable by the keypad when MI2<20. Sorry for such a easy and maby silly question. -- IanM Link to comment Share on other sites More sharing options...
s.pratt Posted February 10, 2015 Report Share Posted February 10, 2015 Hello IanM, You can link a "Disable View" bit to the numeric variable. Then in the ladder, use a compare function block to say "if MI2 < 20, then turn on 'Disable View' bit". In other words, a 'less than' compare function block in series with a coil that is linked to the 'Disable View' bit. Let me know if this helps. Link to comment Share on other sites More sharing options...
