Problem with 1.12.20
mwis750
Hi,
after upgrading UniLogic to 1.12.20 my controler has been upgraded to the following:
#Version List:
Kernel 15.02.01
Kernel_156 15.01.18
File_System 0.0.35
Bin_Files 1.12.7
PLCUpgrade 1.11.1
Now, I'm not able correctly upload any program
- Finalizing downloaded project takes ages and after it's finished (the message in UniLogic: Download Complete. Please check your IP connection settings.) the uploading animation is still running on the panel.
After rebooting there is a message about version mismatch.
After power off and on I can see my application but it looks like functions are not called .... but MODBUS in periodic mode is working ....
Even your examples are not working.
What can be done to make it working again ? UniLog_Backup.zip
If you have rebooted the PLC while the animation was still running, then don't
First, try to do a "Download All". Wait for the program download to end on both the PC side and the PLC side (wait until the animation stops).
If the problem still persist, then please send the project to Unitronics Support for examination, and explain the problem you are experiencing.
Thanks
Thanks
Well,
It didn't finish in one hour. How long should I wait ?
The same occurs if I try to download one of your examples - tested with UniStream_070_Timers_for_UDFB - animation last for at least one hour (I've not waited any longer as it seems something is really broken).
After a plc restart functions are not called. I can click buttons (images are replaced), but timers don't work (no change in current value).
That issue looks like a showstopper to me.
  • 2 weeks later...
  • 2 months later...
