Steve101 Posted February 19, 2015 Report Share Posted February 19, 2015 Hello, Have setup temp control application using V350 PWM via HSO. Was able to run autotune in PID server which seemed to work correctly. Will not autotune directly from controller or run loop. Autotune function block is activated and status says its performing autotune but control value stays at zero. Any Thoughts Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 22, 2015 Report Share Posted February 22, 2015 Hi, Please send your project to support@unitronics.com for review. B.R. Quote Link to comment Share on other sites More sharing options...
