shargy Posted March 2, 2015 Report Share Posted March 2, 2015 Hi Uni crew, is it possible to upload tag values as some kind of backup (let say I want to save PID parameters or other process parameters with my project)? Quote Link to comment Share on other sites More sharing options...
s.pratt Posted March 2, 2015 Report Share Posted March 2, 2015 Hello, Yes, this is entirely possible with use of the data tables and SD card or USB drive. Just save the values you want to back up as a Data Table Indexed, then store the DTI to a file. When you wish to retrieve the value, load the DTI from the file. Let us know if this helps! Quote Link to comment Share on other sites More sharing options...
shargy Posted March 5, 2015 Author Report Share Posted March 5, 2015 Hello, I expected that answer. Of course it is easy to make solution on that way but it can be little complicated when I add some new process parameters I always have to expand DT and dont forget to do that. Maybe would be interestingly to add some similar feature in next versions of UniLogic. Thank You for reply! Quote Link to comment Share on other sites More sharing options...
