Shovelhead1340 Posted March 11, 2015 Report Share Posted March 11, 2015 Hi, I am a new user of Visilogic and installed the latest version in Windows 8.1. I experience the following: 1. Permission 9 denied - When trying to open the program 2. When I manage to open the program I can save but if I try to open the file the program crash. 3. Sometimes I get the message "application is running" when I try to open Visilogic. When I now try to uninstall i get: "An error occurred while launching the setup. the remote procedure call failed" Any advice would be great. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted March 12, 2015 Report Share Posted March 12, 2015 Hello, Please note – for Windows 7 /8 / 8.1 install the software while the Windows UAC is OFF and after rebooting the PC. Please reinstall VisiLogic as follow: Close VisiLogic (if necessary, do it from Windows Task manager) Backup your projects and delete all the files related to Unitronics installations. Erase the “Unitronics VisiLogic_C” folder from- C:\Program Files\Unitronics Erase the “Unitronics” folder from- C:\Program Files\Common Files. Perform Windows update and restart the PC Log-on as administrator Save the setup file on your desktop and make sure that the installation file is not blocked (Right click on the file>Properties) If yes, just click on the unblock button: Install VisiLogic. If software opened properly, Go to the properties of VisiLogic shortcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. I hope it helps.. Quote Link to comment Share on other sites More sharing options...
Shovelhead1340 Posted March 12, 2015 Author Report Share Posted March 12, 2015 Thanks - I will try that. Quote Link to comment Share on other sites More sharing options...
Shovelhead1340 Posted March 12, 2015 Author Report Share Posted March 12, 2015 Hi, I followed your instruction but I still cant open the project. I get "Runtime error 70 Permission denied." Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted March 15, 2015 Report Share Posted March 15, 2015 Hi Please send e-mail to support@unitronics.com so one of the tech guys will help you remotely. Quote Link to comment Share on other sites More sharing options...
CréaSystem Posted June 17, 2015 Report Share Posted June 17, 2015 Hi Shovelhead1340, Did you have a respone ? I have the same problem. Thanksad1340 Quote Link to comment Share on other sites More sharing options...
