navigatoru Posted March 14, 2015 Report Share Posted March 14, 2015 Hi, I am trying to create an action like: 1. PLC starts and shows the initial screen (Home) 2. Have several buttons on the HOME screen 3. Use one of the buttons to navigate to a specific screen (Screen1) 4. After 1 minute, automatically to move to the HOME screen from Screen1 I have done something similar as in the attached picture, but does not work. What could be wrong? When I am using the buttons on the screens to navigate, works well, but not the automatic return to HOME screen. Thanks for clues. Marius Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted March 16, 2015 Report Share Posted March 16, 2015 Have a 1 min timer start when you press a desired button on the home screen. When time expires and home screen is not loaded, set home screen. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 16, 2015 MVP 2021 Report Share Posted March 16, 2015 I'm not sure what you're doing in that 3rd ladder rung, but this is how I'd do it. Quote Link to comment Share on other sites More sharing options...
Kikis Posted March 16, 2015 Report Share Posted March 16, 2015 Link a memory bit to your screen 1 (bit is on when this display is on the screen). Then use this bit as a condition to run 1 minute delay timer and use the direct contact of this timer to load the home screen. Quote Link to comment Share on other sites More sharing options...
navigatoru Posted March 25, 2015 Author Report Share Posted March 25, 2015 Hi guys, Thanks for replies. Were very helpful to find the correct code, which is as in the attached image. Cheers, Marius Quote Link to comment Share on other sites More sharing options...
navigatoru Posted March 25, 2015 Author Report Share Posted March 25, 2015 Even simplier, get rid of the MB500, and will work just fine. Quote Link to comment Share on other sites More sharing options...
