External Moderators tmoulder Posted January 4, 2011 External Moderators Report Share Posted January 4, 2011 Greetings all and Happy New Year! I'm poking around some more on trending, and I saw again something I would like in this feature. My current project involves recording the lifespan of a product under test. I'd like to record the processing time of each test cycle, and trend the results on screen. Unfortunately, trending is strictly time-based, and these tests can be several minutes long, and as the product wears, duration increases. This could be solved with an operand that, when transitioned low to high, would input a data point into the trend. Basically, a "manual record" feature. Thanks! TM Quote Link to comment Share on other sites More sharing options...
Damian Posted January 4, 2011 Report Share Posted January 4, 2011 Greetings all and Happy New Year! I'm poking around some more on trending, and I saw again something I would like in this feature. My current project involves recording the lifespan of a product under test. I'd like to record the processing time of each test cycle, and trend the results on screen. Unfortunately, trending is strictly time-based, and these tests can be several minutes long, and as the product wears, duration increases. This could be solved with an operand that, when transitioned low to high, would input a data point into the trend. Basically, a "manual record" feature. Thanks! TM Hi TM, I like that idea as well. As another alternative, maybe they can make the trending axis a variable. That way you could either assign Unitronics system integers to it if you are looking for a time based axis, or you could assign a User integer for this and have complete control over it. Kind of like a "virtual" time axis. D Quote Link to comment Share on other sites More sharing options...
