pmartino Posted April 29, 2015 Report Share Posted April 29, 2015 Model: Jazz JZ20-R31 I need to only allow access to the first 51 registers (MI 0 – 50). Is that possible? Also some of the registers need to be read only so that any write command would fail. Is that possible? Thank you. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 8, 2015 MVP 2021 Report Share Posted May 8, 2015 Short answer - no. The values are wide open. Joe T. Quote Link to comment Share on other sites More sharing options...
